I have an IP camera that I want to use for license plate recognition. So I put a new Ethernet cable into the patch panel and created my own Ethernet connector on the other side of the cable which connects to the camera. However, I cannot see the camera using SADPTool (for testing I am using a Hickvision cam as it's laying outside on the floor but the final camera will be a Dahua from Andy). SADPTool has no problem seeing any of the other cameras. So clearly I am doing something wrong, most likely with the cabling. On the camera side I used 568B. But then I checked the patch panel that was done by a professional (I copied his outline) and I see that white green = pin 1, green = pin 2, white orange = pin 3, orange = pin 4, white brown = pin 5, brown = pin 6, white blue = pin 7, blue = pin 8. That neither matches 568A nor 568B. Is the patch panel manufacturer just routing signals differently on the PCB? And if so, how do I know if they use 568A for 568B?
