Not entirely sure if this is proper sub to post this in but I've run into a problem with a newer version of the icsee IP camera's I've enjoyed using the last few years.
I've had 4 going older ones and they were working perfectly on IP Camera Viewer 4 or the latest version. I could click on the camera and even track the camera right to left or up and down worked perfectly.
One of them was having issues so I ordered a newer version. Now I can use the VMS lite software that came from the company and get the feeds to work but I can't track them like IP Camera Viewer allows me and I'd rather stick to that.
Issue I'm running into is that the search of the cams find the new one just fine internal router IP noted ONVIF and proper port 8899 just like the others but the sample video doesn't work just says failed.
I've not doing anything differently, firmware updated for that camera but for some reason IP camera viewer does not allow me to use it with this or in fact any other lower end model. I tried one I had new in box earlier and same issue. Now I'm ok with using an alternate software to view all 4-5 cameras or more that I have up so long as I can remotely move them vs having to use my phone app since I have IP Camera Viewer on my desktop computer when I'm sitting around.
Any suggestions pls? I know this site is high on Blue Iris 5 but I couldn't find any data to show that it would also allow me to remotely move the cameras or I may consider tapping into that software and just upgrading the rest of the cameras with the new one.
Just FYI this is the camera I'm trying to use.
Has the dual camera system which is another problem.. even their VMS Lite software won't allow me to just put one feed of one of those cameras into a box to view alone...seems to be split screen which I'm not fond of. I figured they be on diff channels and the software give me option to choose but not sure yet.
ATtaching screenshot of what I'm seeing.
Thanks for any suggestions.
