- Apr 8, 2015
- 175
- 46
Does anyone have a link to some software that will allow you to adjust the settings on a PTZ IP camera?
I want to see things like turn off/on the IR Cut filter, white balance, control the IR lights etc.
The CMS software that came with my camera will do some of the things, but there is NO documentation as to what it will affect.
I can set the IR Filter to be auto or synced with the IR lights, (what does that do?) But I see no setting to just turn it off.
I am sure there is a way to change the user name and password (would do this if I were to stream the camera).
I have the ONVIF device manager which will do some of the things, but not all of them.
I am not looking for software like BlueIris or Ispy. I need configuration software.
Bob
Bob
