Hi.
Hopefully someone can tell me how to setup the HiLook IPC-D120H IP Camera so it can work with HiWatch NVR (NVR-104-E / 4P). I followed the the steps as what the manual says to install the IP camera on the NVR i.e. :
- Activated the 2 IP camera using SADP tool
On SADP Tool the two camera is already on 'active' state (see screen capture)
- On the NVR I choose 'plug-n-play' and ensure that the camera's password matched the NVR's password
But on the NVR's camera management screen, I noticed that it's offline with a message of 'user password error'.
So I tried resetting the 2 cameras to 'default' settings but same outcome - NVR's camera management screen still says camera is offline with a message of 'user password error'
So I'm stuck now on figuring what steps I should to do next as I followed the instructions on
the camera's manual to set it up.
Can someone with a experience in setting up the HiLook IPC-D120H IP camera with HiWatch NVR please tell me what I did wrong or what I missed.
I also what to know if the HiLook IPC-D120H IP camera is compatible with HiWatch NVR (NVR-104-E/4P). For my other IP Camera HiWatch (IPC-B120-I) I did not have this sort of trouble setting it up.
Thanks in advance
Thanks in advance
