Hi all,
What would cause an IP camera on a Dahua NVR (DHI-NVR5464-16P-4KS2) to frequently network disconnect, logout and back in?
I get a feed so I can rule out:
– Bad credentials
– Incorrect image config?
Could it be down to the switch? I have indeed pulled it off the mount and plugged it into a different switch and used a different cable and the same thing happens. It's not a steady enough error to monitor it live, but it does interrupt the timing (it might drop back a few seconds then refresh and join up with live timing again.
I THOUGHT I had fixed this problem last night, I left work satisfied. Now I come in this morning and look at the logs and around an hour after I left it had disconnects from about 9pm all until this morning at varying times.
Any help is much appreciated!
– Bad credentials
