I have an issue with a camera going off line then coming back on in a day, maybe 3.
My setup is 6 IP Cams connected to a WS-POE-48v60w POE Injector using BI software installed on a Dell server. 4 cameras are outside and 2 are inside. All outside cameras are working fine. One inside camera is working fine. I have one that keeps going off line but comes back on in a day or so.
My cameras:
Outside:
(4) Hikvision DS-2CD2032F
Inside:
(1) Hikvision DS-2CD2432F (Just replaced with identical LaView below)
(1) LaViiew LV-PC902F2-W
Here’s what I have tried so far to eliminate the problem.
Replaced network cable…twice
Moved camera to new ports on POE injector as well as the switch
Moved camera power from POE to ac power supply
Installed an identical LaView camera in place of the Hikvision.
All of the above net the same results.
Problem has been going on for roughly 3 months. Nothing has changed inside where the cameras are installed. The second camera inside is basically facing the bad camera and has been working fine since installation 2 months ago.
You can see the other camera above the metal door at the other end of the room, top right corner. I have the same setup at both ends of the building.
Having two cameras do the same thing has me puzzled.
I’m lost. Any and all help would be greatly appreciated.
My cameras:
Outside:
Inside:
