Hi. I’ve recently bought a used HikVision DS-7604NI-K1/4P(B) with 4 DS-2CD1383G0-I cameras. They’ve all been setup and repaired with new activation passwords. 3 out of the 4 cameras connect and display on the NVR. The 4th one no matter what I try just won’t connect. On the NVR it says IP camera does not exist.
I’ve tried multiple cables, I’ve reset it multiple times and tried to connect it to no avail.
If I give it it’s own power source and connect it to the laptop it definitely does work. I can go on live viewer in the browser and it works, I’ve tried giving it a static ip in the NVR range and also the same subnet.
Still won’t connect to the NVR no matter what I do.
NVR is on the latest firmware possible, each update was done one after the other, I didn’t jump to the last one without doing the previous ones first.
The camera is also updated to the latest firmware.
Any help would be appreciated. Thanks.
