IP camera app for Android phone - IP webcam?
JimLS
Feb 8, 2020
56
24
Illinois
Was wanting to set up a temporary camera as an additional one on my zoneminder system. Used IP webcam and it worked for about 5 hours and shut off. I had it powered from a charger so it wasn't battery. When that happened I found a few reports of it crashing. Maybe there are some settings in the phone that need to be changed to never shutdown. But figured I would ask about issues here before I dug too deep. Are there better (free) apps for this?
la camara ip la tenias alimentada por un cargador dices y te duro 5 horas y fallo.
la cámara ip tiene ir? porque puede ser que al anochecer y activarse los ir de la cámara aumenta el consumo y el cargador se quede escaso para alimentar la cámara y por eso te dejo de funcionar
