I am planning to install IP cam using cat5e or cat6 cables. I have some questions and your help and guidance are very much appreciated.
The camera that I plan to use now does not have build in Mic or support Audio in/out. But for future upgraded purposes, Do you recommend pulling two cat5e or cat6 cables per camera, so that i can use the second wire for audio or second wire for camera that support multiple lens? I hope what i said here make sense
For camera that has build in Mic, do I need a separate wire for he microphone ?
Thanks for your help
