Hi,
I purchased 4 IP Cam. Brand Care Cam. They can be wireless or wired. I wired them with Ethernet Cat6 cable to an unmanaged switch box which I connected with Cat6 Ethernet cable to the home router. I downloaded the Care Cam app to my iPhone and they all worked beautifully.completely stable. Each camera is subscribed to the Cloud to upload/download recorded footage.
I then got adventurous and purchased a TP Link VIGI 16 Channel NVR so that I could record 24/7 to the NVR hard drive.
This is when all the problems began.
I have connected the NVR directly to the router and have also tried with it connected directly to the unmanaged switch box. Same issues occur.
I have dynamic IP addresses. I note my router assigns the same IP address to each camera.
The NVR will pick up the 4 IP Cam but after a few hours they will randomly drop off the NVR and the IP Cams will also randomly go offline and I have to restart them all the time. I also note a big problem in the NVR is that when the IP Cam drop off the IP address doesn’t show up with the IP Cam it will just have it as IPC with no IP address showing and this is a big issue as I cannot modify the IP or remove it. If that IP address showed I could just re add the IPC.
I was able to disconnect one IPC from the Care Cam Cloud service and it seemed to work stable on the NVR so I was wondering if the Cloud could be an issue. But Ican’t seem to disconnect the other 3 IPC from the Cloud which have 12 months subscription.
Could it be that the interface of the IPC and NVR are not compatible but then why do they work initially? Or is it the Cloud service causing conflict? Or do I need to ask my Network provider to change my plan to a static IP address?
Hope this all makes sense.
Best regards Paul
Best regards Paul
