Hello,
I currently have a Hikvsion 7608NI-SE (Lorex LN280)
I moved to the mini because I needed more cameras.
Now If only I could get the the time to display on the cameras. I know I can log into the cam itself and add it. But I was hoping the NVR would show it on screen as it does the camera name. And I miss the digital zoom with the ion.
But with the 7 cameras I'm getting some stutter in the live view. And the playback seems to be faster than 1:1 playback ratio. Playback looks odd as you can tell its faster than normal.
So questions:
How can I slow down playback? (FIXED firmware update)
How can I get time to display (makes it easier to find problematic events)?
Where is the digital zoom? (FIXED Right click and make a box and select zoom)
How can I stop the live view shudder and freezing?
Thanks
I did read over the review of the ion 8ch.
I'm currently running the Ion and Hikvision as nvr's maybe this is why the stutter? Using the Hikvision as a POE for now. till I get my POE injectors up and running.
- Combined total recording frame rate of 480 FPS
- Total maximum throughput of 160 Mbps for recording
So questions:
Thanks
