- Jan 2, 2017
- 10
- 1
I've been researching surveillance systems on and off for years and really picked up the pace the last few months. I've stumbled on many forum threads looking for information and an Amazon review I read pointed me here.
A little bit on me: I live in a small town about an hour north of Seattle, married, one kid and another on the way. I have an electrical and electronics background and work a technical blue collar trade. I live in a 100 year old 2 story house with a detached 500 sqft garage, alley access, corner lot on the intersection of two moderately busy streets.
I'm aiming to install a 4 camera POE system. My initial budget is in the $300-$600 range and I'm open to starting to with just one camera and installing the rest over a few months. I want to have high quality video saved to the hard drive, android and iOS access (Roku would be a plus also!), remote access from a browser, motion detected stills uploaded to FTP would be nice... I honestly don't know what features I want aside from what all of them do to varying degrees.
I can't seem to decide on going with a prepacked NVR system, purchasing NVR and cameras separate, or going the PC/Blue Iris route. At this moment I'm leaning Blue Iris but if you wait five minutes I could change my mind.
Assuming the $300-$600 price target, here's how I interpret each and please correct me if I'm wrong.
Prepackaged NVR System
Pros: Least expensive, easiest to integrate, this is what my wife prefers I do
Cons: Limited features, probably a bad mobile app, proprietary, difficult or impossible to expand, you get what you get, support could be an issue
Hand Selected NVR System
Pros: Hand selected components, ability to expand, better features
Cons: Compatibility issues possible, most difficult to configure, likely little support aside from forums
PC/Blue Iris
Pros: Hand selected components, ability to expand, best features, best mobile app, lots of flexibility, easiest to repair/replace, best support and resources
Cons: Most expensive, could be a little difficult to configure
Does that sound about right? Anybody have any comments or advice? Thanks!
PC/Blue Iris
