- Sep 25, 2017
- 3,074
- 3,984
I have had an interesting thought recently that I thought might be of a wide interest to the community. Unfortunately I don't have the means to test it but if anyone does, maybe a project for someone....and may settle the dabate of CPU vs GPU...
So the thought is, in these times of sky high and rocketing energy prices, which is the more energy efficient DS+GPU or DS+ CPU?
You might think the answer is obvious - CPU, but I don't think it's that clear cut.
Here's why and what would be interesting to test.
Power Consumption depends on load.
So running a CPU + 50w GPU such as a Quaddro P620 might seem to be a simple case of CPU + 50W. However...... DS + CPU will put the CPU under load so the CPU will use more power, whilst DS + GPU will remove the load on the CPU but add load to the GPU. However no: 2 - the amount of power the GPU draws will also be dependent on load so if the GPU isn't under a lot of load, the draw could be a lot less than the 50W specified for the card. So this then raises the question of, is the energy requirement of DS + a highly loaded CPU less than the energy requirement of DS + a lightly loaded CPU + a lightly loaded GPU (assuming here a P620 is going to kick it unless DS is processing a lot of cameras). even if the GPU does make it less efficient, what is the gap. eg you'd assume it was 50w just from the specs but what if cosnidering the diferent loads and power draws it came out to only 5-10W? It might then be worth swinging one way or the oher because the difference was so small.
So the question, is does anyone want to test this for the community to discover a definitive answer? I would but my CCTV isn't installed yet (I have other projects physcially blocking the installation atm) plus I don't have any way of measuring power draw. I think if someone was in a position to test though the results could be interesting at best or at least draw a line under it at worst.
