Hello
On a 6320 hikvision screen I have wifi connection to the internet that is working.
The screen is connected to a hikvision poe switch.
The switch is also connected to a kv 9503 door bell unit. There is a connection between the units
Is it possible to share the wifi connection from the screen to the doorbell unit if I put the doorbell unit in a wired network mode? Will it get the connection from the screen?
The question is because when I try to connect from hik connect te door bell is offline. When I try to connect to the switch a cable from the router the door bell is online. The problem is that in the installation area I can't get the cable from the router from the switch so I want to share the wifi connection via the cable from the screen to the switch and from there to the door bell
Possible?
Possible?
