tangent
- May 12, 2016
- 4,641
- 4,000
I was throwing some labor into my crude estimates as well as things like UPS and racks and dedicated machines and screens for viewing. I was figuring $10k is about the minimum no labor, but it could easily be more. I'd be genuinely curious about your take on the choice between Dahua, DW, and Hanwha (formerly samsung) cameras for a higher end commercial install. Hanwah and Bosch are the ones I think I've noticed in the field the most.You dont really need to spend 20k...
2100 for the vms
2000 for pc and storage (can even do it for 1k if shopped right)
4-6000 for cams and the network gear...
Avigilon is also a great option, but will cost much more...and does not have the free upgrades...
Also, Digital watchdog provides a discounts on the camera license if you buy a DW camera...
@BrewFixer you might want to consider buying a membership to IPVM Video Surveillance Information there's lots of information there you might benefit from.
