Now that 6.x with built in AI has been out awhile I decided to give it another try. I had been using CPAI with YoloV8 Medium on a GTX 1660ti. Just switched to internal using YoloV8 Medium and the same GPU.
I used to look at the CPAI dashboard to see how it was performing, but obviously that doesn't work with the built in AI.
How are you comparing performance between the two? The only metric I know to look at is the analysis details but the round trip times are all over the place there regardless of which AI engine I'm using.
