Hi - I've got several cameras set up in Blue Iris, using Dual Streams, continuous recording. When triggered the recordings switch to the Main Stream and the quality is excellent, as I would expect. However, when I look at the recorded video during untriggered periods, the quality of the video is intermittently much worse than I would expect given the substream settings. All my cameras have the substream set to D1 or VGA as available, using VBR, quality Better, max rate around 768 k.
When I watch the recording, the quality seems to keep shifting in and out. Is there some setting I'm missing ? Here's an example from one of them showing the variation I see over a minute or two - this is from a Empire Tech IPC-T5442T-ZE, zoomed out to its widest. I'm not sure if what I'm seeing is a focus shift - and if it is, why this is happening.
