- Dec 18, 2014
- 23
- 0
Hi,
I've set up the Hikvision 2432 which I'm overall very happy with. Occasionally though, I notice that some frames are dropping. That is, if I have the date/time showing up on the image, it will jump a few seconds forward (e.g. from :03 to :06). That happens when I access the main stream via ONVIF using a baby monitoring app for iOS. I can also reproduce this with the official Hikvision app. However, if I use the app to view a lower resolution version of the feed, it seems to be much smoother.
Any ideas why I'm seeing this? I'm assuming the usual suspect is WiFi, though the camera is getting a pretty good signal (approximately -47dB).
