new house set up with Wired PoE Cams:
(4) Hikvision DS-2CD2563G0-IS (6MP)
(3) Hikvision DS-2CD2365G1-I (6MP)
all with static IPs assigned.
powered by D-LINK DGS-1100-08P (64W power budget, cams come in at 62.5W total)
the PoE switch plugs into a USB 3.0 Ethernet port that feeds into a homebrew i3 / 12G RAM NVR.
Running Blue Iris v4.
Every cam will lose signal for a few seconds and then pop back up on Blue Iris. Repeatedly.
this same setup worked fine at my last house when i had 4 hikvision cameras, but they were older / lower MP cams. no disconnect issues.
Where should i start to get more stable connections with the Cameras?
Thanks in advance
Thanks in advance
