- Dec 21, 2017
- 1,288
- 1,201
Hi folks,
I'm building out a small surveillance system for my home. Currently have 3 cams going (all Hikvision) connected to a Hikvision DS-7608NI-I2/8p NVR.
I'll be buying a couple more cams and see lots of references to "Andy" as a vendor but haven't found his website yet. Could someone please direct me?
And, I could use a recommendation for an inexpensive interior garage cam. Needs to work with the NVR but doesn't need to be fancy. Will be in a corner, shooting to the opposite corner diagonally, about 30 feet. No IR vision needed, and even a 720p cam would be fine for this application. But, it should be robust and stand up to heat well, since the garage gets quite warm in the summer. Thoughts?
Thanks. I'll post some build pictures this weekend, mostly for amusement value of the denizens of this wonderful site.
