I've recently added some Hikvision cameras to my Dahua NVR, and while the 24/7 recording works fine over the same LAN using ONVIF with updated security settings, I'm encountering issues with motion detection (MD) and joystick control.
Specifically, I'm trying to get the MD to work seamlessly, and I also have a Hikvision PTZ tunnel rush camera that I'd like to control with a Dahua NKB1000 joystick. However, the control and panning of the camera do not work as expected.
Has anyone successfully integrated these systems and can offer advice on the following points?
1. Motion Detection Configuration: What are the best practices for configuring MD settings when combining Hikvision cameras with a Dahua NVR?
2. Joystick Compatibility: Are there any known compatibility issues or special settings required to use a Dahua joystick with Hikvision PTZ cameras?
3. ONVIF Profiles: Could the issue be related to specific ONVIF profiles or settings that need to be adjusted for proper communication between the devices?
