- Jan 30, 2018
- 22
- 2
Hi,
I am installing about 16 IP cameras across a youth camp. We are getting fiber runs to all the areas where cameras will be. I am completely clueless on an infrastructure with this amount of cameras. Can I get some advice on what to look at?
Here are some of the needs I would like to have:
1 - NVR with 24/7 recording (can be two separate NVRs since there are 8+ cameras?)
2 - high resolution with ability to digitally zoom in
3 - NO mechanical or Pan Tilt needed
4 - good IR for night time
5 - Most can be hardwired POE but would like a few to be able to connect via wifi
6 - ability to connect and view remotely
7 - a good user interface to control alarm push notifications
I have read a little bit about Onvif. Is that like where you can by mixed brands of onvif supported cameras and connect them an onvif supported NVR? I have seen a pacakge of a Camius Professional 16 channel NVR with 8 POE 5mp Bullet cameras for a pretty amazing price. But I want this equipment to be reliable and almost feel it's too cheap to be true!
Thank you very much for your help.
