Cupofschmoe Young grasshopper Apr 13, 2017 80 21 May 17, 2017 #1 Any pointers and tips on drilling and securing the cameras?
zero-degrees Known around here Aug 15, 2015 1,335 845 May 17, 2017 #2 use water while drilling so you don't smoke the bit. Plan on junction boxes so you can keep your exterior holes small and complete wiring inside junction box. If the stone is not flat assure you seal everything up tight since water will be getting behind your camera and or junction box.
Kawboy12R Known around here Nov 18, 2014 1,763 609 May 17, 2017 #3 Z-d has good points. Also, watch some YouTube videos. Sometimes watching shows things that are hard to catch from reading instructions and hints. "Drilling stone" or "drilling stone and stucco" etc are good starting search points. Reactions: Cupofschmoe
fundean Young grasshopper Jun 23, 2016 31 6 May 18, 2017 #4 Tapcon... at Lowes or HD... work beautifully won't need any lubricant although hammer drill is recommended Sent from my iPad using Tapatalk Pro Reactions: Cupofschmoe
Cupofschmoe Young grasshopper Apr 13, 2017 80 21 May 18, 2017 #5 Looked at some YouTube videos and picked up some Tapcon screws. No hammer drill so I'll take my time with the regular rotary. Reactions: fundean
