25x PTZ Camera Specification:
Image Sensor 1/2.8” STARVIS™ CMOS
Image Size 1920(H) x 1080(V), 2 Megapixels
RAM/ROM 1024M/128M
Electronic Shutter 1/1s~1/30,000s
Minimum Illumination Color:
[email protected]; B/W:
[email protected];
[email protected] (IR on)
S/N Ratio More than 50dB
Video Output N/A
Day / Night Auto(ICR) / Color / B/W
BLC Mode BLC / HLC / WDR(120dB)
White Balance Auto, ATW, Indoor, Outdoor, Manual
Gain Control Auto / Manual
Digital Noise Reduction Ultra DNR (2D/3D)
Privacy Masking Up to 24 areas
Optical Zoom 25x
Digital Zoom 16x
Electronic Image Stabilization (EIS) N/A
Defog Support
Wide Dynamic Range 120dB
DORI Distance
Note: The DORI distance is a “general proximity” of distance which makes it easy to pinpoint the right camera for your needs. The DORI distance is calculated based on sensor specification and lab test result according to EN 62676-4 which defines the criteria for Detect, Observe, Recognize and Identify respectively.
Detect
Observe
Recognize
Identify
1613m(5292ft)
646m(2119ft)
323m(1060ft)
161m(528ft)
Focal Length 4.8mm~120mm
Max. Aperture F1.6 ~ F4.4
Focus Control Auto / Manual
Angle of View H: 62.8° ~ 2.6°
Close Focus Distance 100mm~ 1000mm
IR LEDs 6
IR Distance Distance up to 100m (328ft)
IR On/Off Control Auto/Manual
Pan Range Pan: 0° ~ 360° endless; auto flip 180°
Pan Speed Pan: 0.1° ~200° /s
Tilt Range Tilt: -15° ~ 90°
Tilt Speed Tilt: 0.1° ~120° /s
Number of Preset 300
PTZ Mode 5 Pattern, 8 Tour, Auto Pan ,Auto Scan
Speed Setup Human-oriented focal Length/ speed adaptation
Power Up Action Auto restore to previous PTZ and lens status after power failure
Idle Motion Activate Preset/ Scan/ Tour/ Pattern if there is no command in the specified period
Time Task Auto activation of Preset / Pan / Scan / Tour / Pattern by preset-time
Video Compression H.265+/H.265/H.264+/H.264
Video Resolution 1080P(1920×1080)/720P(1280×720)/D1(704×576/704×480)/CIF(352×288/352×240)
Video Frame Rate
Main stream: 1080P/720P(1 ~ 25/30fps)
Sub stream1: D1/CIF(1 ~ 25/30fps)
Sub stream2: 720P/D1/CIF(1 ~ 25/30fps)
Video Bitrate H.265/H.264: 448K ~ 8192Kbps
Auto Tracking Tracking the specified target
IVS Tripwire, Intrusion,Abandoned/Missing
Tracking Trigger Mode N/A
Tracking Trigger Event Motion detection, Video tampering, Network disconnection, IP address conflict, Illegal access, Storage anomaly
Audio Compression G.711a/G.711Mu/G.726/AAC
Audio In 1CH
Audio Out 1CH
IPC Alarm YES
Alarm In 2CH
Alarm Out 1CH
Ethernet RJ-45 (10XBase-T/100Base-TX)
Network Protocol IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS,PPPOE,
DDNS,FTP, IP Filter,QoS,Bonjour,802.1x
Network Interoperability ONVIF Profile S&G, API
Streaming Method Unicast / Multicast
Network Max. Users 20 users
Storage NAS (Network Attached Storage),Local PC for instant recording, Micro SD card 256GB
Storage Card Micro SD card 256GB
Web Viewer IE, Chrome, Firefox, Safari
Management Software Smart PSS, DSS, DMSS
Mobile iPhone, Android
Certifications CE: EN55032/EN55024/EN50130-4
FCC: Part15 subpartB,ANSI C63.4- 2014
UL: UL60950-1+CAN/CSA C22.2,No.60950-1
RS485 N/A
Power Supply DC 12V/3A, PoE+(802.3at)
Power Consumption 13W,20W (IR on)
Operating Temperature -40°C ~ 70°C (-40°F ~ +158°F) / Less than 95% RH
Ingress Protection IP66
Dimensions Φ6.3(in) x 11.6(in)
Weight Net Weight 3kg(6.61lb) Gross Weight 4.2kg(9.26lb)
5MP WDR Turret IP Camera Specifications:
Image Sensor 1/2.7” 5Megapixel Progressive CMOS
Image Size 2592(H) x 1944(V), 5 Megapixels
RAM/ROM 512MB/32MB
Electronic Shutter 1/3s~1/100,000s
Minimum Illumination 0.03Lux/F2.0(Color,1/3s,30IRE)
0.3Lux/2.0(Color,1/30s,20IRE)
Video Output N/A
White Balance Auto/Natural/Street Lamp/Outdoor/Manual
Digital Noise Reduction Ultra 3D DNR
Privacy Masking Off/On (4 Area, Rectangle)
Digital Zoom 16x
Smart IR Support
Focal Length 2.8mm (3.6 mm optional)
Max. Aperture F2.0 /F2.0
Focus Control Fixed
Angle of View H: 96°/78°, V: 70°/58°
Close Focus Distance N/A
IR LEDs 12
IR Distance Distance up to 30m (98ft)
Pan/Tilt Range Pan: 0° ~ 360°; Tilt:0°~90°;Rotation:0°~360°
Event Trigger Motion Detection, Video Tampering, Scene Changing, Network Disconnection, IP Address Conflict, Illegal Access, Storage Anomaly
Video Compression H.265+/H.265/MJPEG(Sub Stream)
Video Resolution 5M(2592x1944)/4M(2688x1520)
Video Frame Rate
Main stream: 5M(1 ~ 15fps)/3M (1 ~ 25/30fps)
Sub stream1: D1(1 ~ 25/30fps)
Video Bitrate H.265:12K~8448Kbps
H.264: 32K ~ 10240Kbps
Network Max. Users 10 users/20 users
Certifications CE: (EN 60950:2000)
UL: UL60950-1
RS485 N/A
Power Supply DC 12V, PoE (IEEE 802.3af)(Class 0)
Power Consumption < 6W
