Ok, I am getting IR reflection on a couple cameras I mounted under the eve of the house. How much drop would I need to fix that. I was thinking of using a outdoor weather proof electrical outlet box. I used this method to mount a camera on top my metal awning camera fit perfect on the box. I just had to drill a hole in the side to run the wires and marine gooped that. My camera is not facing down it is adjusted all the way up to see for distance. I did mount them very close to the edge but still have some issues. Yea i know I am using my cameras different then most of you.
