I am about to install two POE Amcrest cameras on the exterior of my home. I don't have the option to run the cables inside my home then drill a hole to pop the just the cat5 cable part out to the camera, leaving the unused 12v adapter inside.
Instead, I need to mount the camera and run the cable down to the basement and run into my gear from there. The challenge is the 12v pigtail coming out of the camera. I'll use the CAT5 cable connection and the cover they include - so that will be nice and weather proof. I just don't know what to do w/ the 12v Plug that I won't be using (the part I circled below.)
Clearly I don't want to leave it exposed to the weather. Should I just cut it off and wrap it up?
Curious what others have done.
Thanks.
Thanks.
