wcrowder
The airfibers are even more fun
Sent from my SM-N920V using Tapatalk
Yeah, but I don't think he needs 15 mile range or to spend $3,000.00 for a pair... LMAO....
...Quit trying to force an IP system on somebody who doesn't want it. Thank you.
You know, Charlie Chan once said "Mind, like parachute, only function when open."
Okay...I talked to the farm owner and he did settle with IP...
Okay, from what I've been reading on this subject, let me make sure I'm understanding correctly. These satellite dishes/bridges need a roughly unobstructed view between each other, correct? There are a handful of trees between his shop, field and grain facility, but not a lot.
He has a 50ft radio tower at his shop, I'm assuming I'll need to put one dish/bridge on his radio tower, run Cat5 down conduit to his shop and connect it to his router. Then I'll need to put the other dish/bridge at his grain facility, perhaps on top of one of his silos? Then run Cat5 down conduit to his tin shed and connect it to the POE/Toughswitch. Then comes the issue of how to run Cat5 to his cameras. Any suggestions on that?
Is this roughly correct?
I've attached some pictures and a diagram too to make sure I'm understanding everything correctly and so you get an idea of how everything looks.
View attachment 6893View attachment 6894
It will work with ease if your worried step up to the 19dbi model
Tell me...was it the Charlie Chan quote that turned you around?
Just run cat5 to your cameras from the PoE switch. The uplink out of the switch goes to the bridge, through the PoE injector that comes with the Ubiquiti device. We like using the loco M5 nano station.
So if I understand this correctly, at the camera site I will need a poe switch and the poe block that comes with the loco m5?
