Good Morning Colleagues
I hope you are doing good . One of our customers need to install Hikvision Intercom DS-KIS604-P . I have successfully configure it , integrate the door station with the indoor screen in addition to integrate with Hik-connect .
My issue is the integration/connection between the Door station and the door lock . I really have very little experience with such cable/wiring connections .
I have found the below video describing the wiring between the door station and door lock . From your experience , Does those connection is correct ?
Best Regards
Best Regards
