Hey all. Finally getting close to mounting some cameras.
I have a question on the proper way to mount to an exterior brick wall(above a garage door where there are no soffits accessible or low enough).
I'm attaching an image of the wall construction(as far as I'm aware).
I'm planning to use one of these turret mounts for a dahua camera that I bought a while back. Plan is to use masonry anchors to attach.
Camera is a dahua turret, model number escapes me at the moment.
My main question is how to best prevent water intrusion.
A silicone seal around the top, sides, and some of the bottom of the mount seems appropriate.
What about the hole for the ethernet? My thought was to drill in at a slight upward angle(exaggerated in image) so any moisture behind the brick is less likely to come to the inside.
Smaller is better so I'll minimize hole size.
Any other things I should try to do?
