H Huthaifa n3wb Oct 4, 2015 13 0 Oct 18, 2015 #1 The problem solved, ask for close the thread. Thanks Last edited by a moderator: Oct 19, 2015
fenderman Staff member Mar 9, 2014 36,891 21,408 Oct 19, 2015 #3 Huthaifa said: The problem solved, ask for close the thread. Thanks Click to expand... If you have a problem and its solved the best thing to do is to post the solution...this way someone in the future can benefit. Deleting the thread helps no one. Reactions: Travieso
