Initial Setup on Android
ZigBlazer
Jan 5, 2018
12
I'm trying to get Blue Iris setup on my phone and tablet. Followed the instructions from a few different places, but I believe it is stuck with the port forwarding. It will connect from both the phone and tablet if they are connected to the same network that the computer is, but over 4g it is unable to connect. Running the Wizard in Blue Iris, everything checks good until it gets to checking that the port forwarding is working. I disabled the firewall just to check, and there was no change. I've tried changing the ports, and forwarding several times. Currently I have it setup under port 8081 and double checked my WAN. But anytime I check it, there is no response.
I'm not sure where the disconnect is, and couldn't find any forwarding directions specific to the Calix 844G modem/router. I believe I set it up correctly, but it isn't working. All cameras and my computer are set with static IPs.
