OK so if I have 20' of underground POE cable and another 20' indoors on one end to connect cameras; another 20' or so indoors on the other end to connect to the server:
1 What is the best underground cable to use? http://www.outdoor-ethernet-cable.com/?
2 Is it better to continue the use of the underground cable on both ends indoors, or will it degrade the signal if I use connectors on each end and switch to indoor cable on each end?
3 Also can anyone explain these wires in an Ethernet cable?
