- Jun 12, 2017
- 19
- 2
While I continue to research what cameras I'm going to use on the exterior of the home, I think I would like to get a couple indoor cameras. Something hopefully fairly simple that you can set on a table or desk that will blend in fairly well. I don't believe I need PTZ functionality as long as I can the correct lens to cover the room. I also don't believe I need PoE as I will have power and network both places I want to put one of these.
What's the go-to indoor table-top cam the group recommends these days? And I just want to say the only reason I'm in this Dahua forum is that seems to be the most recommended brand from what I've seen so far. I'm not stuck on them, so if there's a different brand you guys might like better....
