Incomplete clips
Aug 14, 2018
1
Michigan
My clips are triggered by motion. When I play them back, some clips are incomplete. For example, It records me getting into my vehicle, but if I wait to long, my vehicle disappears and it doesn't show me pulling out of the driveway. I have a pre-roll set for 3 seconds which works as intended. Is there a post roll to keep recording if motion stops?
yes, its the break time set in the trigger tab. Also, if you are using direct to disk recording it will only start on the iframe, therefore set the iframe interval in the camera settings to match the fps.
