Improve night motion image - HFW5842E-Z4E
Sapp
Aug 24, 2023
3
3
Poland
Hello, i'm trying to achieve better motion image (especially faces) at night. My camera is mounted ~3,5m above ground level and its ~15m from the target. The slowly moving face looks alright but when i start running its too blurry to identify (maybe its enough for recignition if you know the face). I have two other camers looking at the same direction and there is street light around. I triend different shutter speeds etc. but no more clue.
These are my settings:
and videos:
- running
- walking
i use firmware version: V3.142.0000000.3.R, Build Date: 2024-09-24
It would be really helpfull if you could pass me some tips :)
Maybe set Saturation and Sharpness to 40-45. Shutter to 4 or 5, and Gain to 50 to see if it help or not. Your video looks pretty good already. Sometimes it's just the camera's own limitation and not the setting that's the problem.
and videos:
- running
- walking
It would help if you post your Night settings, those look to be Day settings?
Use h.264.h which is the best quality codec
Also are you running SMD and IVS at the same time? I see tearing on the last few frames of the both videos, it could indicate the camera's resources are being strained. Use IVS only and turn off MD/SMD
Cut back on sharpness, try about 42-44
Try 40 on 3DNR
Play with Gamma and see effects on that pixelization
The 4MP version of that camera is much better at night, they use the same sensor and the 8MP is strained in low light.
Reactions: JDreaming
I see, I will try to change these and see the result, thanks
Try 40 on 3DNR
I use only one profile for both day and night, is this much of an issue? I will check the codec and AI functions. Sadly I couldn't buy the 4mpx version, I have the Z12E version next to it and it's working perfectly for reading plates at night so I just assumed all I need bigger zoom - didn't work as good as i thought haha
Its not all that bad. If you're happy with the daytime image sure. Most run separate profiles.
For instance in daytime you could run 0-3 exposure.
IR set to Manual 100?
Its tough as the 8MP just doesnt pick up the light as well as the 4MP.
To reduce the blur on the faster objects you'll have to have a faster exposure, like 0-5 or more. But the image will get darker.
