Hi guys,
I have a problem with a hikvision nvr (HWM-4104MH-4P) and two Imou cameras (IPC-F22AP).
My router have ip: 192.150.0.1, cameras is static ip 192.150.0.50 and 51, nvr ip is 192.150.0.100.
NVR have 4 ports with POE, if connect camera to one of this ports i cant find my camera. This ports are other ip range? Or is the same ip range of main nvr ip?
Now have connected with a POE adapter to router port, in this case we can find camera, launch ConfigTool of Dahua and initialize camera (set ips, ports (37777 as default), etc)
One problem is that if put ip in web browser not load web interface of camera (try with port 80 and 37777)
If in hikvison web portal add manual camera, config ip, etc, hikvision always put port as 80 (onvif protocol). Camera is show as online, but image never show
Need connect cameras to poe ports of nvr, and need show and recorder video... any solution?
Regards
Regards
