T tevege n3wb Oct 26, 2021 1 0 Slovenia Oct 26, 2021 #21 cudejko said: Hi, what are you supposed to do with those two pins exactly ? As i got it opened, but then i got stucked. thanks. Click to expand... Connect camera, shortcut pins for +10sec: -> auto reboot, reset to factory settings.
samgor93 n3wb Jan 21, 2025 3 0 Bangladesh Jan 23, 2025 #22 Will this POE injector work with IMOU F22AP ip camera then? Tenda PoE15F 10/100Mbps PoE Injector_Tenda-All For Better NetWorking Tenda PoE15F 10/100Mbps PoE Injector www.tendacn.com
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 21,029 49,839 Alabama Jan 23, 2025 #23 samgor93 said: Will this POE injector work with IMOU F22AP ip camera then? Tenda PoE15F 10/100Mbps PoE Injector_Tenda-All For Better NetWorking Tenda PoE15F 10/100Mbps PoE Injector www.tendacn.com Click to expand... Based on what I read in your link to the injector and the specs for that camera I'd say "yes". It says it will work on 220V @ 50Hz as in your country but you may need a plug adapter to get it to fit your 220V socket. Reactions: samgor93
samgor93 n3wb Jan 21, 2025 3 0 Bangladesh Jan 23, 2025 #24 TonyR said: Based on what I read in your link to the injector and the specs for that camera I'd say "yes". Click to expand... I tried to feed 12v but it didn't turn on. So, I will try this injector then. Thank you for your response.
N nejakejnick Getting the hang of it Aug 30, 2015 140 25 Jan 23, 2025 #25 samgor93 said: I tried to feed 12v but it didn't turn on. So, I will try this injector then. Thank you for your response. Click to expand... Yep, Dahua needs 48V POE. Reactions: samgor93
