Hi!
I currently use this url
I am wondering, is there a way to tell blue iris that I want a high def picture from the main stream and are willing to wait, if it has to start decoding for that?
I made that up but what I need is some URL parameter like:
or
any ideas?
...I implemented some kind of heuristic currently. The image dimension do not change when the stream changes but the high def image from the main stream needs more kB! If the file is too small, I keep fetching it in my node red flow until it is larger. But I noticed last night that the night time images are way smaller in file size, even the high def one so the logic breaks there.
http://blueirisIP:81/image/Cam1?user=...&pw=...&q=90 to fetch a picture of Cam1. This camera is 4k and uses substreams and the first picture is from that substream only. If I repeatedly reload the image it switches to the main stream and privdes better images.I am wondering, is there a way to tell blue iris that I want a high def picture from the main stream and are willing to wait, if it has to start decoding for that?
Code:
...&forceStream=main
Code:
...&forceStream=sub
