Yeah, I searched for a while and couldn't find the info I was looking for. Thanks!There’s a massive thread on this in which I think you’ve actually posted, is a bit of a read but lots of useful info in there.
Thanks. I'll check out the link. I'd like to run the GPU version.See the below link
If you are using a GPU you need to install CUDA and run the cuDNN install script first
If you are using CPU then just install the latest
I just ran the Code Project AI install and my 2060 worked out of the box. It setup the entire dashboard as GPU. I didn't even know I was supposed to install CUDA. I'll have to look into that.See the below link
Did you have CUDA install before for DeepStack?I just ran the Code Project AI install and my 2060 worked out of the box. It setup the entire dashboard as GPU. I didn't even know I was supposed to install CUDA. I'll have to look into that.
I don’t recall doing it for anything before. Used as my main desktop and light gaming. I haven’t had time to test fully yet. All I did was install CP AI and run the benchmarks. Haven’t actually used it for BI yet.Did you have CUDA install before for DeepStack?
Here is my screenshot:
You need to checkoff Use custom model folder and set the folder to C:\Program Files\CodeProject\AI\AnalysisLayer\ObjectDetectionYolo\custom-modelsI'm getting closer. How do you tell CPAI to use ipcam-combined custom model? Here are my settings, I would appreciate a peer review.
Try rebooting to see if the CPAI service restartsThanks @MikeLud1, I made that change and restarted the BI service. I have noticed that when you restart the BI service, it doesn't restart the CPAI service. After manually restarting it, here's what I have.
Yes, that works. I noticed a v1.6.5 notice in the CPAI dashboard. I tried the download but it didn't work.Try rebooting to see if the CPAI service restarts
Just downloaded it. They must have not had the link right when you attempted. Trying to find the release notes though is a pain since the codeproject web page is a bit of a mess.Yes, that works. I noticed a v1.6.5 notice in the CPAI dashboard. I tried the download but it didn't work.
Where did you find this? Browsing their source code, they don't even have any changes after 1.6 which is eight day old: GitHub - codeproject/CodeProject.AI-Server: CodeProject SenseAI is a self contained service that software developers can include in, and distribute with, their applications in order to augment their apps with the power of AI.What's New - 1.6.5.0
- Patch 1.6.5: Multi-setting updates via API, ability to force half-precision support, YOLO nano-sized model added
- Patch 1.6.2: Fix for more nVidia cards, MODE=High bug fix
- Patch 1.6.1: Catching issues on pre-win10 machines, fix for GTX 1650/60 cards
