It may still be active.was informed to turned off Port Forwarding on my router and that would clear it up.
Suggestion : Before you do that - check with ShieldsUp!I will factory default my router in the next week or so
Ah, but, I just thought, if you've now disconnected the NVR from internet access, no connection from the internet will happen, even if port forwarding is active.It's easy peasy to use, and will tell you quickly and clearly what ports if any are open to access from the internet.
