Under Camera Properties > Video > Configure > Network Options
1) What is the ideal "Receive Buffer" to use with Hikvision 3MP and 4MP cameras and what are the pros and cons of setting it too low or too high?
2) I've looked through a number of threads which seem to indicate that 20 MB is what is suggested (mainly by Fenderman), but is there an advantage to going higher (or disadvantage)?
I've got plenty of RAM to spare as my system is an i7 with 32GB of RAM. I'm running 18 cameras and my CPU usage is usually around 25% with an FPS of 10 on most cameras. I occasionally get some ghosting on the recordings and was wondering if I should just crank the receive buffer up to 50MB per camera.
I should also point out that I did read the Help file but did not find any information regarding the receive buffer.
Thanks for your help!
