While I do have some time, haven't found the deals and when I do, they are 4th generation or older. Since I have enough spare parts, looking at doing a build as essentially all I need is CPU, MB and memory. Currently have 3 cases/PS, 256SSD for OS + Blue Iris, and 4TB WD Purple, monitor, keyboard and mouse.
Maximum cameras at 8 (2mb Starlight and perhaps a couple 4MB turrets) with Dahua 8 port PoE switch.
First question, should I splurge for the i7 Kaby Lake 7700 or will the i5 Kaby Lake 7600 be sufficient? $220 vs $305 (there is no discount for Skylake as they are priced identical so stick with Kaby Lake!) Non-"K" models as overclocking isn't necessary and they come with the stock cooling fan.
Motherboard - Gigibyte GA-B250M $70, Designed for Kaby Lake with the Intel 250 chip and won't have to flash bios like the older Skylake boards with the H or Z110 chip. Has 4 SATA connectors to add additional hard drives. Have to be careful as the base Dell I priced out when reviewing the manual the custom motherboard only had a single SATA for no expansion! I couldn't even add the WD Purple to the Dell if I wanted too.
Memory - G-Skill/Corsair preferred brands, DDR4 2400; 2x4 $75 and 2x8 $135
Total: i5 with 8gb memory $365, 16 gb memory $425
i7 with 8gb memory $450, 16 gb memory $510
Yes will need an operating system and noted New unused Windows 10 Pro OEM keys for around $25 on Ebay with good user reviews. Is it critical Pro vs home in case I have to go full retail $100/150 on the operating system?
