took 4 hours just to see livestream image on Blue Iris
Updated firmware to the latest greatest. Couldn't figure out the correct URL for RTSP using the standard Dahua camera menu options. Model was not listed in the configure/make & model (ended up using M/P/Q series H.264) Finally, from some vague mention of Axis no likey Intel HW decoding here on IPCT ( Hardware Acceleration with Axis Cameras ), I set decoding to 'no' for the Axis 3006-V and the RTSP stream came right up. Oddly, M1054 is instead set to 'default' and still streams. Both receive buffers are set to 20mb (per advice in other postings). Find/Inspect only set the camera's to Generic ONVIF which didn't do much good.
This 3006-V is a 3MP no-infrared dome camera you see in retail stores. Not sure why there were 2 x M1054's in there. They seem kind of like...doorbell or front door cameras. Only 720p at that.
Since no night vision, I'll be setting these 3 3006-V's into my woodworking shop (above table saw looking down, same for planer/jointer, same for Roubo workbench). Not sure what to do with the M1054's. Wonder if they can be used for front door cam's. One on each side
