I am looking for my first PTZ camera. I am considering the DS-2DE7184-A but rather than say poe+ it shows as "High-POE". Is there a difference and what am I looking at as far as install options if it's different than POE+? Getting ac to my mounting location will be difficult. I currently use a standard POE switch.
On a side note has anyone used the auto tracking feature available on the Pro series and do you think it would be worth it? I use a synology as my NVR and was wondering if autotracking would be something the camera would handle much like motion detection so I would be able to utilize it within Synology's Surveillance Station.
Thank you,
James
Thank you,
James
