So, I'm working on a project in my mind where I will replace a lot (50+) of analog cameras with IP cameras. My existing cameras are basically web cams that also put out an analog stream through a converter. The analog input goes to a NVR/DVR, the web cam output is used by kiosk software to record a stream when someone is using the kiosk. I can seemingly hook up any webcam to the kiosk software and get it to record, if it shows up as a camera in Windows then I can choose it and the kiosk side is good to go.
I'd love to use something like the Hikvision Cube cameras mounted behind the glass of the kiosk and get a 3mp IP stream to record to the NVR, but how can I get the camera to show up as a webcam on the kiosk? I have tried a couple of software programs that are supposed to be able to do this but have had no success with getting it to work with Hikvision cameras so far anyway. I've only worked on this for a few hours but thought I'd ask before getting too deep if anyone had ideas.
I'm open to other cameras, cube style will be perfect seemingly, so if one existed that worked as both that would be awesome. Or if there is software that will emulate a webcam (that works!) and could be configured to load as a service and work automatically at boot that would be great too. Seems the software I've tried so far cannot find a http mjpg stream to connect to on my Hiks so maybe another camera would work.
Just looking for ideas, thanks all!
