I need help accessing and exporting logs from a Dahua doorbell.
Dec 18, 2025
1
Albania
I’m a developer trying to access doorbell unlock logs via an API so I can display them in other systems, but I can’t find any API endpoint or permission that exposes these logs.
I do have SSH access to the device, but I don’t have root privileges, so I’m unable to access system files or code directly. Because of this, it appears there’s no supported way to retrieve unlock or event logs from the device.
Have any of you run into this limitation before or found a workaround for accessing these logs? Additionally, is it possible to configure the device to send event information (for example, when a card is checked) to a specific endpoint using a supported protocol?
