I need assistanse for dhi-dss7016d-s2
TIGOS1
Feb 25, 2020
66
17
Odessa, Ukraine
My server suddenly lost connection to all devices on the network (i see that in DSS AGILE at my phone).
I went from PC to the ADMIN web-panel and chose Reboot there.
After the reboot, all web panels stopped being accessible from the local network, and all programs stopped connecting (dss client and dss agile).
Also on port 6379 the following message is displayed:
--------- табличка с порта 6379 -------
Redis is running in protected mode because CLOSED protected mode is enabled, no bind address was specified, no authentication password is requested to clients.
In this mode connections are only accepted from the loopback interface.
If you want to connect from external computers to Redis you may adopt one of the following solutions:
1) Just disable protected mode sending the command
'CONFIG SET protected-mode no'
from the loopback interface by connecting to Redis from the same host the server is running, however MAKE SURE Redis is not publicly accessible from internet if you do so. Use CONFIG REWRITE to make this change permanent.
2) Alternatively you can just disable the protected mode by editing the Redis configuration file, and setting the protected mode option to
'no'
, and then restarting the server.
3) If you started the server manually just for testing, restart it with the
'--protected-mode no'
option.
4) Setup a bind address or an authentication password.
NOTE: You only need to do one of the above things in order for the server to start accepting connections from the outside.
In addition, access via ssh (port 22) is available from the local network. But unfortunately I don't know the access password.
In the system parameters, it was configured to make a daily backup. But it is impossible to download it from the server, because there is no access to the server files.
After many hours, I tried to connect to the server from applications - the server opened, but all functions were offline.
I opened the SYSTEM web panel from my PC, performed the backup manually.
Here is the backup I was able to download.
But I don't know what to do next.
the server is down.
In addition, I downloaded LOGS from the ADMIN panel.
