didotec n3wb Jan 8, 2022 3 0 United States May 30, 2022 #1 I need a ip camera with pre record 30 seconds. I found only max 5 seconds. I don't wanna use nvr to do this
L LopezEL Getting the hang of it Sep 30, 2019 97 90 SC May 30, 2022 #2 Best option is Record continuously to an SD card. Then you can review all footage. Reactions: sebastiantombs and samplenhold
sebastiantombs Known around here Dec 28, 2019 11,502 27,730 New Jersey May 30, 2022 #3 To get any buffered, pre-trigger, video whether its 3 seconds or ten minutes, the camera needs to be constantly recording. It can't go back in time to get what happened previously any other way. Reactions: TonyR and genelit
R Rob2020 Known around here Oct 2, 2020 1,094 2,728 OR USA May 30, 2022 #4 I record 24/7/365 with Blue Iris. Works 100% with no drama or glitches, been recording continuously now for well over one year. Once you start recording 24/7 you will never go back to motion type clips only (assume that is what you are mentioning). Reactions: SouthernYankee, Broachoski, TonyR and 2 others
