Hi, look at my post count, I'm new!
I read an awesome post from Mat on another post about what to look for:
- Mat, if you are reading this, I gave you a like. Will read the links later.
Right now to the meaty bit.
As I said, I got burgled the other day, I was celebrating my 5 year anniversary with my fiance, we will call her Steve.
So Steve and I were out celebrating at a nice restaurant she wanted us to go to. I have a smart home setup, however, I don't have any cameras, I just recently bought some motion sensors in the living room and kitchen, but Batman needs a face and mine is for radio only.
So I'm going to break my requirements down to component parts, I'm still a handsome newb to cctv so please bear with me.....
IP Camera
NVR
Any help would be greatly appreciated! I haven't decided on a budget yet, nothing cheap, nothing rediculous? I have a girlfriend but she knows when something is fishy....
Welcome CJ555,
For your zillions of questions:
It's easy to get swamped with information here, so I wanted to share some notes with you
Please check out @giomania 's notes:
Dahua Starlight Varifocal Turret (IPC-HDW5231R-Z)
I have also made notes which are a summary of a lot of the reading I've been doing here,:
Looking for some advice and direction!
Have fun joining us here.
PS - look at Cat5e or Cat6 solid copper wires from Monoprice
From my notes at another site:
Cat 5e / Cat 6 ethernet cable:
DO NOT buy CCA (Copper Clad Aluminum) wire - it is a fire hazard
- Recommended that you buy buik cat5e/cat6 cable and not use the cable which comes in the kit, as if you need to return it you will have to also return the cables.
 - Recommended vendor for bulk Cat 5e / Cat 6 cable is monoprice, they often have sales during the weekend.
 - Either Cat 5e or Cat 6 cable will work with these cameras. Normally Cat6 cable is a bit thicker due to the plastic separator in the cable. Also Cat 6 cable often has wires slightly thicker than what you see in Cat 5e cables. While a thicker copper wire means less voltage loss over the run, it may not be significant for most of us. Note the spec for ethernet and PoE is 100M / 328 feet.
 - If you are pulling multiple wires through 1/2" EMT pipes or other tight spots it maybe better to use cat 5e.
 - If you are only buying one bulk box of cable you may want to get cat6 in case you would like to wire up other locations.
 - There are numerous types of Cat 5e / Cat 6 cable, you want to get Solid unshielded cable, either for in-wall installation or plenum rated cable ( better for multistory buildings and business type buildings ).
 - If you plan to have the cables exposed to direct UV get a UV rated cable or place the cable in conduit. Otherwise, the cable will degrade over time.
 - Also get RJ45 ends which are rated for solid wires, as well as a crimping tool.
 - Remember to cut the cable longer than you think you will need, and leave some extra length in case you need to adjust the location a bit.
 - Recommend pulling N+1 or more cables to each location, where N = number of cameras you plan to have. This way if you decide to add an additional PoE or ethernet device nearby you can in the future.
 - If your attic is too short to easily work in recommending using Grey PVC pipe 3/4"+ and pushing the sections to the locations you want to run the cat5e/cat6 cabling to.
 - Have a friend help you pull the cabling so you can reduce snags and knots which may cause breakages. Also, remember not to pull the cable with too much force as it is more delicate than electrical cables that you may be used to pulling.
 - You can use the pull tools which electricians use to help with the wiring pulls.
 - Unshielded vs shielded cable - typically you can avoid using shielded cable, just try to keep the cable 1 foot or more from electrical lines, fluorescent lights, and electrical motors. If you must pass by something which produces EMF / electrical interference you can use a section of EMT pipe in that location to pass the cat5e/cat6 cable through.
 - Thieves have been known to cut telcom cables to houses as well as cat5e/cat6 to cameras - if you feel the need to protect your cables do consider putting them in conduit or run the lines inside the wall. ( Metal EMT works well in most cases, in humid environments, you may want to consider less strong non-metal conduit. )
 - I like using the 568-B standard: http://www.incentre.net/wp-conten...le568b.gif If the link is not working please see the attached gif at the bottom of the wiki
 - Here's what looks like a good write up on crimping the ends: https://www.warehousecables.com/l...-cable.php
IP Camera
I'm hoping to get a 4k starlight sensor camera with 60fps (I'm not a fortnite gamer.) The 60fps requirement is because I want a crisp image against motion as burglars are sneaky and fast, but I weigh 18 stone and have gout. so need to get a nice crisp image for Batman.
I have seen the below video and thought Dahua would be the way to go
But I have since seen so many versions and no real sellers. That I am now not sure.
NVR
In total I'm going to get 4 cameras for outside, however I'm wondering if I'll want to expand in future... I'm not saying I'll spam cameras, but I want something future proof, so something that can support around 6 4k cameras, POE, great software that can hook into a smart home system would be great... unfortunately the only stuff I've seen so far is that ubiquiti stuff that just isn't good for 4k setups... nice looking software though... everyone loves bootstrap!
Not sure what else I need, I know Matt said get some sweet cabling for weather, burglers etc so I'll look into the cabling based on his recommendations...(I'm looking at you Monoprice!)
