I-frames issues help!
Mofo84
Nov 15, 2017
25
25
I just installed blue iris on a new computer and imported setting and transferred over my license. But 2 of the cameras are not getting 15/1 frames.
Any ideas?
That is what you want with BI.
1.00 Key means the FPS and iframes match.
The Key is a ratio, so 15/15 = 1.00
You will have to set the FPS to 15 and the Iframe settings to 15 on the web configuration page for each camera! This is not controlled by BI!
I also notice that one of your cameras is set to use H265 compression, you probably should change it to H264, which is the recommended configuration for BI
I do have them like that . Also when I change the camera that was in H265 to H264 the frames do this
Oh I missed the bottom two, but the subs are at a Key of 1.00 and that is the important one for motion detection.
I am guessing hidden in the camera GUI somewhere is some AI analytic or coding that is causing that low KEY.
